88 oliver needs HP
trapper
01-16-2002 18:45:51
i have a 88 oliver gas and i want more HP to make a puller. what can i do to get more hp and where can i find the parts i need.if someone has any parts for sale email me [email protected]
Don L.
01-17-2002 05:00:56
 Re: 88 oliver needs HP in reply to trapper, 01-16-2002 18:45:51
NOS 1100 Massey head,1100 Massey manifold used, and a used 7700 JD carb for $1600. Ph 507 433 0073
Oliver Nut
01-17-2002 06:20:59
 Re: Re: 88 oliver needs HP in reply to Don L., 01-17-2002 05:00:56
Is that 1100 MF head crossflow? What is so great about it compared to the Oliver head?
art
01-17-2002 17:29:06
 Re: Re: Re: 88 oliver needs HP in reply to Oliver Nut, 01-17-2002 06:20:59
1100 heads breath alot better. They are usually expensive to buy and alot of places prohit their use. 4 1/4 or 4 3/8 chevy pistons on 77 rods with the crank ground offset will give you 383 or 396 (i didn't do the math). Get all the air you can through the head and use the bigger super 88 intake or 1650 intake and exhaust. One of the later cams will help. Motec can make your carb flow all the head will take. Bigger than that requires a stroker crank and clearencing. Art
