Good Low RPM Tachometer?
Mopower
11-23-2004 06:45:09
I see Denny's sells a 0-3000 tach for pullers. Thought about getting one to entertain myself with. Is that the only place you can get one? My tractors won't ever run much over 2000.
BUD BARENIE
11-23-2004 15:33:06
 Re: Good Low RPM Tachometer? in reply to Mopower, 11-23-2004 06:45:09
BOUGHT ONE FROM NAPA. SAME SIZE AS THE STNDARD GAUGES. GOOD FOR 4-6-8 CYLINDER MOTOR'S
0-4000RPM'S NICE UNIT !
Patches
11-24-2004 16:47:03
 Re: Good Low RPM Tachometer? in reply to BUD BARENIE, 11-23-2004 15:33:06
Is the NAPA tach electronical or mechanical? A testing tach or permanent on the tractor? If electronic do you have a part number so I can call my local NAPA store.
Thanks,
Bruce
Drew
11-23-2004 10:31:43
We have a digital Cyberdyne on an A John Deere. It works great! It reads out to 10rpm increments.
dctom
11-23-2004 07:20:58
mopower, i got one from car quest store for my DC, works fine i only run 1500 lol tom
Mopower
11-23-2004 07:22:28
 Re: Good Low RPM Tachometer? in reply to dctom, 11-23-2004 07:20:58
Thanks. Was it a 3000 rpm tach you bought?
dctom
11-23-2004 09:33:17
 Re: Good Low RPM Tachometer? in reply to Mopower, 11-23-2004 07:22:28
yah i guess for 1500 needle dont go up very far
AC
11-23-2004 09:56:26
 Re: Good Low RPM Tachometer? in reply to dctom, 11-23-2004 09:33:17
1500 rpms is straight up on my tach. Look for a motorola boat tach. Real nice, 3" wide, 2 wire hookup, 0-3000 in 500 rpm increments. I have 5 or 6 of them....AC
mark h
11-23-2004 13:45:08
 Re: Good Low RPM Tachometer? in reply to AC, 11-23-2004 09:56:26
Ethan, go to summitracing.com they have 2 5/8 tachs, 3000 is about as low as you'll find.
