Narrow or Wide rear wheel distance
don44
11-20-2004 21:46:04
Should I slide my rear tires all the way in or out. what is the best what are the advantage or disadvantage on this thanx for your help
slowsmoke
11-21-2004 04:55:56
 Re: Narrow or Wide rear wheel distance in reply to don44, 11-20-2004 21:46:04
if you pull a sled with a narrow pan, then setting tires to a wide stance to avoid the pile of dirt in front of the pan may help. otherwise, set them where you can see them from the driver's seat, so you can see what they're doing.
LumbrJakMan
11-22-2004 06:22:36
 Re: Narrow or Wide rear wheel distance in reply to slowsmoke, 11-21-2004 04:55:56
I like mine in tight as can be also, Gives me a better footprint where the sled just was and keeps it solid under the rubber . I also can change my offset and sometimes still get a piece of the hard ground under each tire !
Two-Tone
11-21-2004 05:25:12
Set the tires as narrow as practical! Wide setting tries to torque steer the tractor, therefore makeing it harder to go straight.
tt
Hillbilly Hooker
11-21-2004 19:41:03
 Re: Narrow or Wide rear wheel distance in reply to Two-Tone, 11-21-2004 05:25:12
My thoughts exactly TT . The closer the better. H.H.
