KILL SWITCH
J.D. R BOY
11-19-2004 13:28:06
HOW DO THEY HOOK UP A KILL SWITCH ON A J.D. DIESEL?
thejdman01
11-20-2004 07:17:41
 Re: KILL SWITCH in reply to J.D. R BOY, 11-19-2004 13:28:06
has to be air like esp wiht 318 2 stage detroits you could shut the fuel off but possibly it would start sucking enough oil and keep running. to be totally safe sure and what most sanctions want is an air shut off
Lstallbaumer
11-20-2004 01:09:36
Use the decompression system. Have the kill line hooked to the rod that is pulled back by the decompression lever to decompress the engine. Build a latch system so when the kill line is pulled it pulls the rod back ad releases the catch / dog to keep the decompression rod from comming back forward. We put a key ring in at the sled end of the kill line so that if it does get used the key ring will act as a shear pin and keep from tearing up the decompression system. Brother did it that way and it works well.
AC
11-19-2004 14:16:35
Maybe some way you could run a direct wire to the pump, so if it breaks away, it'll pull the pump back, and just have a little hinge for the wire to catch on....???I have no good idea...AC
JDH
11-19-2004 17:27:22
 Re: KILL SWITCH in reply to AC, 11-19-2004 14:16:35
The only real way is to cut the air off. It can be as simple as a rain flap with a wire to keep it open and run the wire to the back or a guilatine shut off.
