880 oliver build-up
kwf
11-16-2004 06:04:47
What would be the easiest, and/or least expensive, and/or best way to get about 100 horsepower out of 880 gas?
Hulkster
11-17-2004 10:01:22
 Re: 880 oliver build-up in reply to kwf, 11-16-2004 06:04:47
Build a Diesel, I here there is one being built in southern IN.
Think I know
11-17-2004 14:13:10
 Re: 880 oliver build-up in reply to Hulkster, 11-17-2004 10:01:22
It aint the Schmit boys is it? They got some tough ones already, good lookin too. Good people, help you any time they can.
kwf
11-17-2004 11:28:58
What would you do to the diesel to get 100 hp with stock looking and 10% over rpm limitations.
green man
11-17-2004 13:04:20
 Re: 880 oliver build-up in reply to kwf, 11-17-2004 11:28:58
I pull an 880 diesel that is around 90 horse power with stock RPM. I have 3 7/8 MandW pistons. I had to machine the pistons and the head so they would work. I had the head and manifold ported and polished and larger valves installed. I got rid of the american bosch injection pump and am running the roosamaster off an 1800. I also have the injection lines and injectors from the 1800 with increased pressures. Running stock RPM it was dynoed at about 90 horse. Doing this will also leave ur tractor reliable. I take this tractor and plow with it at our local antique tractor clubs plow days. I am running it at about 3500 RPM and is very competitive in our local open classes.
tractor pullerks
11-17-2004 20:53:28
 Re: 880 oliver build-up in reply to green man, 11-17-2004 13:04:20
or when that a jd beats you hahah
A.P.
11-17-2004 02:19:48
Order up a set of Darton sleeves with either a 4 1/4" or 4 3/8" bore. These will require block machining to fit. The 4 1/4" bore will give you 340 cubes and 4 3/8" will give you 360 cube. Use stock rods but have the small end bushed to match the pin diameter of the pistons. You may have to offset the hole in the bushing to come up with the correct piston location at TDC. Get your cam reground or use a 1650 cam. Install larger valves and seats in the head. Get the head ported and match the ports of the manifold to the head. Pay attention to detail and tuning and you should be over 100 horse
Kwf
11-17-2004 04:29:30
 Re: 880 oliver build-up in reply to A.P., 11-17-2004 02:19:48
Thanks for the replys. Where is the best place to get the sleeves and piston set. Also, can a good machine shop make the offset piston pin bushings?
Paul Winter
11-16-2004 17:14:09
depends on your rules some rpm plus bigger pistons will get ya there. limited rpm will need 5.5" plus stroke and 4.25" plus bore turbos and super chargers will get there also. if rules alow a 7 main block and head good place to start.Paul
kwf
11-17-2004 04:37:08
 Re: 880 oliver build-up in reply to Paul Winter, 11-16-2004 17:14:09
We are only allowed 10% over rpms. How much can you stroke it without having to cut on block?
IH
11-16-2004 15:48:17
Buy and pull an M Farmall instead....
green man
11-16-2004 16:31:42
 Re: 880 oliver build-up in reply to IH, 11-16-2004 15:48:17
Sorry IH he wants to win. Somthin u cant do with a Farmall M. Everyone knows an 88-880 oliver can beat an M. U can go alot further with an 88-880 than u can an M. Division 4 and 4 4500-5500 Oliver owns em.
REAL PULLER
11-22-2004 18:40:46
 Re: 880 oliver build-up in reply to green man, 11-16-2004 16:31:42
WELL I WAS PULLIN IN MISSOURI WITH THE N.A.T.P.A THIS PAST WEEKEND... WELL AS FAR AS I COULD SEE THE OLIVER WERE NOT EVEN CLOSE TO THE FINISH LINE, THE FARMALLS DOMINATED HEAVILY IN DIVISON 4 CLASSES 4500-5000 5500-6000. SO WHAT DO YOU THINK ABOUT THAT OLIVER BOYS..
sos puller
11-16-2004 15:40:21
put a 1800 engine in it
