Compresion or bore size
JDadapter
11-15-2004 11:47:39
Is the bore size as important if you get the compresion up or is it better to go with a bigger bore and get the compresion up?
nc jd guy
11-23-2004 19:55:04
 Re: Compresion or bore size in reply to JDadapter, 11-15-2004 11:47:39
I agree with BushogPapa but wanted to add a little. WHen you go thru the thermodynamics, compression ratio is a direct multiplier. Now, due to efficiencies, this gets really distorted. Rule of thumb - raising compression ratio will actually net about half what it should... Keep in mind that the larger the bore, the harder it is to burn all the fuel that is in there. STROKE is in my opinion, the best way to make power for this type of work. Stroke costs a little more upfront, but the added torque as well as Cubic inches will really pay out.
BushogPapa
11-15-2004 18:50:04
There is NO substitute for Cubic Inches....
Ron.
