M-450 block
Crank Yanker
11-11-2004 12:44:24
Can M components (crank, cam, rods)be put directly in a 400-450 block? My M block is cracked and I am looking for a stronger block.
Thanks
CY
Crank Yanker
11-12-2004 07:59:52
 Re: M-450 block in reply to Crank Yanker, 11-11-2004 12:44:24
Thanks for the info men.
RED WHEELS
11-11-2004 17:07:44
The main bearing bore in the block is the same diameter from the M to the 450. The newer engines just used a thinner bearing insert.
Flogger
11-11-2004 14:21:54
Yes indeed. Everything from the M block will work in the 450, except the sleeves and pistons.
superih
11-11-2004 14:50:50
 Re: M-450 block in reply to Flogger, 11-11-2004 14:21:54
Aren't the main journals different sizes.
Flogger
11-11-2004 18:57:40
 Re: M-450 block in reply to superih, 11-11-2004 14:50:50
I think the Ms from 200,000 serial # range got the bigger journal crank. Red Wheels is correct they used a thinner bearing insert with the bigger crank.
CASEPOWER
11-11-2004 20:22:15
 Re: M-450 block in reply to Flogger, 11-11-2004 18:57:40
278050 and up are the same..
