What can be use in the IHC H engine
Punchie
11-03-2004 18:03:17
Will a 300 UTILITY PISTON W/ ROD SET C-169 ENGINE fix in a 1939 H ?
I'm planning on using this tractor , I may pull for fun at local fair.
Going to have to put a new sleeve set in it. If I use a 300 flat top piston and a 300 head , or would it be better to use a H head ground down?
SuperH
11-04-2004 17:05:52
 Re: What can be use in the IHC H engine in reply to Punchie, 11-03-2004 18:03:17
You will need to bore the block to use the 300 sleeves.
AC
11-04-2004 08:47:54
I have the 350 head and manifold you need to make good [email protected] thought I'm mention it....AC
Migraine
11-07-2004 08:20:36
 Re: What can be use in the IHC H engine in reply to AC, 11-04-2004 08:47:54
Where abouts are these 350 parts and what do you want for them? Whats the no on the 350 head. Reply or email hnunnikhoven @yahoo.com Thanks Migraine
