What size pressed steel wheel for a JD A
Padd
11-03-2004 12:08:54
I am looking at some options of pressed steel wheels and I have a question as to should I go with the 38" or with the 34". Is there any advantages to the smaller tire such as weight, and price, etc.
2 Cylinder
11-03-2004 17:06:02
 Re: What size pressed steel wheel for a JD A in reply to Padd, 11-03-2004 12:08:54
I preferred the 38" over the 34". If you are stock horsepower try the 15.5 x 38", if you have 50-55 horsepower maybe 14.9 x 38", if you have more than 55 hp you could try the 16.9 x 38". If you have the late model JD-A with the low 1st gear you can probably take your pick of the ones I mentioned above. But above all check the rules of the places you plan to pull to see what tire sizes are allowed. Hope this helps!
52 A
11-04-2004 17:29:49
 Re: What size pressed steel wheel for a JD A in reply to 2 Cylinder, 11-03-2004 17:06:02
I have a 52 A John Deere, and I ran 18.4x38 cut tires on 18" wide rims. Stock tractor with power block and pulled 5500-6500 easily.
