roosa master pumps
turboman
11-02-2004 18:47:02
how do your turn up a roosa master pump like whats on a 4520?.just want to go about 10%
Farmall Doctor
11-05-2004 18:00:47
 Re: roosa master pumps in reply to turboman, 11-02-2004 18:47:02
Look at the back of the pump,just below the top cover, and you should see a cap if it's still there, or an allen screw at a 45* angle. If your pump is older than that, it will be on the side of the pump, on the left side of it. This is the "torque screw" Turn it out about a turn, and you will see a difference. If that isn't enough, give it another turn out- you won't hurt anything in the pump. It adjusts how far the metering valve will open. If you keep turning out and you don't get the results you want, you will have to crank down on the plunger spring inside the pump which is not as easy. Give it a try, and I can help you if needed- I just rebuilt the Roosa Master on my 706. Regards, FD
turboman
11-07-2004 01:00:24
 Re: roosa master pumps in reply to Farmall Doctor, 11-05-2004 18:00:47
Yep ,that did it !!!!! thanks FD
