flywheels
mo-powa
11-02-2004 17:52:27
Does anyone have any opinions on whether or not puting a G flywheel on an A would be beneficial in anyway? Stock, or strokers. Will the crank stand up to the extra weight?
jddude
11-03-2004 14:43:41
 Re: flywheels in reply to mo-powa, 11-02-2004 17:52:27
1 have an a with (38)a g flywheel (f481r). splines does not poke all the way through flywheel but it does help
mo-powa
11-03-2004 15:45:51
 Re: flywheels in reply to jddude, 11-03-2004 14:43:41
But would you put one on a big stroker? I realize it needs to be re-balanced as splines are slightly off from A crank.
BushogPapa
11-03-2004 12:09:13
You would have to have it Balanced to the same specs as the "A" flywheel.. The splines are probably not the same size.. I like the idea of a heavier flywheel on higher powered 2- Cylinder engines...it would smooth out the impulses that can break traction... 4, 6 and 8 cylinder engines can use a lot less flywheel weight than a 2-Cylinder...they don't need the mass, to carry engine momentum to the next power impulse.. The extra weight certainly won't hurt, as long as it is safely done... I have often thought of "sweating" a 1/4"thick ring over the outside circumference of mine, to increase the flywheel mass.. It could be secured with rivets, or short bolts threaded into the flywheel..
ChadS
11-03-2004 12:24:19
 Re: flywheels in reply to BushogPapa, 11-03-2004 12:09:13
In our deadweight pulling club, there is G JD's with plate steel flywheels welded together, lots bigger in diameter than stock, lot thicker too. They seem to hold together well. I agree with ya, I think it does smooth em out, never seen em die, or spin out. Just right. on asphalt.. ChadS
