opinion on V8 mod antique mod chasis
truckntractorman
11-01-2004 18:41:07
i"ve pulled antique tractors for over 10 years and became very competitive and now i"m bored so i want to move up a notch. all we have ever had are ford tractors but they didn"t make a big tractor that you could put a 460 in. she needs to be strong, able to handle 400+ hp oliver 88? cock shut 55? allis wd? fordson major diesel?
V-8 Man
11-04-2004 16:32:37
 Re: opinion on V8 mod antique mod chasis in reply to truckntractorman, 11-01-2004 18:41:07
I pull a Farmall M with power supplied by Chevrolet.It is a blast and becoming very popular in Michigan.Lots of pulls with organized clubs.Farmall M,400,& 450's hold up well.Also,lots of Oliver 88's.Get to the shop and start building one.You won't be dissappointed!
Biohazard
11-04-2004 05:24:29
If you want to stay in the Ford family and run something unique, email me, I can help you with beefing up a Ford 6000 to handle what you want to do.
Also, I have seen the MH 101 chassis mentioned by others. These work okay, but I have had trouble blowing the pinion shaft out the front of the tranny. It is easy to prevent by replacing the front cast iron pinion shaft cap (bottom left on the front of the tranny) with a steel one.
Doug Potter
04-20-2005 12:15:11
 Re: opinion on V8 mod antique mod chasis in reply to Biohazard, 11-04-2004 05:24:29
looking through the net and saw that you have the knowledge on how to beef up a Ford 6000. Would appreciate your help?
Doug
Firefarm
11-02-2004 07:31:22
Make sure you check the rules in your area before putting a big block in anything. Just don"t want to see you build something that you can"t run anywhere. Alot of the pulls out East only let you run 3000 rpms with a big block. Give me a e-mail if you have any questions.
770 Puller
11-01-2004 19:42:08
Massey 101 Trans. and rearend held a Hemi for years. Hemi ran V- cuts 18.4's X 38 s. Tractor ran in the 70's.
Puller time
11-01-2004 22:06:56
 Re: opinion on V8 mod antique mod chasis in reply to 770 Puller, 11-01-2004 19:42:08
Cockshutt 40's are without a doubt the strongest rear end built upto 1960. Oliver and massey arent very far behind. The only problem with massey was they had a little less gear selection. But they are as strong as any. The 40 cockshutt is virtually indestructable though.
Ironman
11-02-2004 06:58:47
 Re: opinion on V8 mod antique mod chasis in reply to Puller time, 11-01-2004 22:06:56
Cockshutt 40/50 (they're the same) rear ends are your best bet. They will handle 3,000 horsepower.
Puller time
11-01-2004 22:06:08
Cockshutt 40's are without a doubt the strongest rear end built upto 1960. Oliver and massey arent very far behind. The only problem with massey was they had a little less gear selection. But they are as strong as any. The 40 cockshutt is vertually indestructable though.
crewter
11-12-2004 20:22:40
 Re: opinion on V8 mod antique mod chasis in reply to Puller time, 11-01-2004 22:06:08
Whay about tranny options?
Brad
