Farmall IHC Tractors Discussion Board
Punchie
10-25-2004 16:38:41
Ok have and older duel fuel H 1939-1941 Very low Hours 1000-1500.
Need to re-sleeve the engine.
What would be the best kit to use as far as size and company?
Now for the head, what would be the best there?
Tractor to be redone totaly , may take to fairs and may pull with it, but mostly a farm tractor. I 'm not looking for a hot rod but would like a warmer rod , 40 + HP if I can get it.
Did the H come with a HIGH COMPRESSION PISTON , high step like our super H ?
Will an M carburator fit an H, will this make and more power?
How much more power will a 300 Head add?
I'm thinking a kit for a supper H and a 300 head with a manifold that is newer 300 size. should be around 30-
35 HP.
Thanks!!
Teddy
Punchie
10-25-2004 16:41:27
 Farmall H about to start engine work, sleeves etc in reply to Punchie, 10-25-2004 16:38:41
Wrong subject
FERGFARMS
11-02-2004 15:59:30
 Re: Farmall H about to start engine work, sleeves in reply to Punchie, 10-25-2004 16:41:27
USE THE 350 KIT YOU WILL HAVE TO BORE THE BLOCK FOR THE SLEEVES TO FIT.THE 300 OVERBORE KIT HAS THE SAME SIZE PISTONS,BUT WITH THE LARGER WRIST PINS.
