'48 JD G reduction gear
MSKOCH
10-24-2004 20:30:10
Does anybody have any info about installing a reduction gear in a G. I've seen them on A's but was curious about a G. Any info is appreciated.
Dougie
10-25-2004 18:12:32
 Re: '48 JD G reduction gear in reply to MSKOCH, 10-24-2004 20:30:10
I thought about getting one for my G, but the ones I saw were exspensive. Spend your money on other things or get smaller tires. I like the high fast gear (mine goes a hair under 4 mph) cause it gives you more momentum to pull the sled. IMHO
Dougie
Droopy
10-29-2004 16:48:09
 Re: '48 JD G reduction gear in reply to Dougie, 10-25-2004 18:12:32
I am intersted in a reducton gear also. Where would I ind the expensive ones you talked about? I pull stoneboat and donot pull tranfser sled.
Dougie
10-30-2004 08:38:41
 Re: '48 JD G reduction gear in reply to Droopy, 10-29-2004 16:48:09
Droopy, are you spinning out or choking? If your spinning out, don't worry about it. I was talking to a guy who helps me gets parts for my tractor. That's where my head, block, pistons, clutch parts and other parts I'm sure of. If your choking, I'll ask the guy when the reduction gear stuff is.
Dougie
Droopy
10-31-2004 06:06:42
 Re: '48 JD G reduction gear in reply to Dougie, 10-30-2004 08:38:41
Dougie, I spinout just above idle. Thank You for any help.
Dougie
11-01-2004 14:05:28
 Re: '48 JD G reduction gear in reply to Droopy, 10-31-2004 06:06:42
What kind of maniflod do you have? I was doing this till I got a Jerry's Manifold ($265) and it helped me a lot.
Dougie
Droopy
11-01-2004 17:34:17
 Re: '48 JD G reduction gear in reply to Dougie, 11-01-2004 14:05:28
I have a Johnson cold gas. Power is not the porblem, traction is. The cub I pull with does not permit cut tires. DREW
Dougie
11-01-2004 18:20:52
 Re: '48 JD G reduction gear in reply to Droopy, 11-01-2004 17:34:17
What size tires do you have? E-mail me at [email protected] and I'll tell you how to sharpen tires w/o cutting them. I have 16.9-34's on my G.
Dougie
Mike G JD
10-26-2004 17:55:55
I was at a pull with my g last weekend ,and a man told me that he had taken the large gear to the rear of the clutch off an A ,and had the crankshaft gear made to mesh with the gear off of the A.
