Chad here is the results !!!!!!!!
Buckmaster
10-23-2004 16:02:35
well i started in the 5500 class they alow cut tires you can run any thing you want as long as you stay under 3mph i may cut mine well i hooked on 5500 only weights i had on was the 2 150 lbs wheel weights and its 5500 on the money i pulled it 234.28 for a 5th place finish super 77 and 88 olivers won all the lower spots they had cut tires and who knows what else im sure me and my buddy that runs a wd45 is the only 2 stock ones there but i hooked on 6500 didnt place but i didnt run out of power either i was happy so i went all out and borrowed weights and hooked on in the 7500 didnt place but i pulled it further then the 6500 and still didnt run out of power the m done real good i think the olivers didnt hook 7500 i thought it was funny the only thing out there was me and a whole heard of john deers the plugs was a light brown so how do i get one of your gouvener springs with out driving to indiana im in south eastern ohio. what do you think about cut tires mine are old good years 14-9-38 the front end was just right just at a nice float by the way every time i spun out both rear wheels spun at the same time every time did the super m have a locker? i need one of your springs if you can let me know how to get one thanks Buck
