for Chads; head gskt?
trulyred
10-19-2004 07:10:09
Do you have copper head gskt. for Farmall 400, 4 1/8 bore? Please email me so I may call you.
ChadS
10-20-2004 09:11:46
 Re: for Chads; head gskt? in reply to trulyred, 10-19-2004 07:10:09
Yes, I have a few left, Do you want it at stock thickness, or thinner? Another question is is the block sleeved? the sleeve standout, holds the gasket up off the block and make sealing a pain,, but,, there is a solution,, make the bores of the gasket bigger, to fit over the sides of the sleeves. make it thinner,and gain some compression. Hope this helps, email me if you have questions, ChadS
