Limited slip?
Tedjohn
10-18-2004 20:36:42
Whenever I pull my tractor one rear tire spins out. I see the other guys break out both tires at the same time and they go farther. How do I tighten up the differential so both wheels pull evenly?
Big Yarber
10-19-2004 09:23:09
 Re: Limited slip? in reply to Tedjohn, 10-18-2004 20:36:42
when i pull i just use the brakes so slow down the tire that is slipping. so that they both spin at the same speed.
ohiojoe
10-19-2004 14:10:21
 Re: Limited slip? in reply to Big Yarber, 10-19-2004 09:23:09
I would almost kill to find a way to put/make a limited slip in my ZA, Hitting the brake will slow down your motion I think, I lean toward the spinning tire that helps. But like a drag race car limit slip would be a BIG help(just don't lock your back tires)
ChadS
10-20-2004 06:44:41
 Re: Limited slip? in reply to ohiojoe, 10-19-2004 14:10:21
We have them for the MM IH, OL, MH, and a few others. ChadS
Jak
10-20-2004 11:09:14
 Re: Limited slip? in reply to ChadS, 10-20-2004 06:44:41
I have had good luck just watching the tires(parariphial vision,guess thats how its spelled)and barely easing down on the one spinning faster.ChadS,are your units like a Detroit locker or do they have clutch plates?
