wd45D
mf440
10-15-2004 17:52:03
I was woundering if you could put sleaves and pistons from a cockshutt 50 in to a wd45 diesel motor
JDGnut
10-16-2004 07:19:08
 Re: wd45D in reply to mf440, 10-15-2004 17:52:03
I'm sure some Cochshutt expert will correct me.. but I don't think the Buda 274 has sleeves... You can put the 262 sleeves in the 230 block... but it not a drop in deal.. the orings are on the sleeves on one.. in the block on the other.. The best thing to start with a 262 off a later engine.. but if you are going to sleeve it bigger it really won't matter unless you want to use the later injection pump..
Do you have your head off yet??? Those things are nasty about cracking... the block between the sleeves.. and the head around the injectors and power cells.. (usually cranks are harmless in the head..)
Good Luck
JDGnut
