WEIGHT?
JACK
01-09-2002 18:51:47
I AM JUST GETTING STARTED IN TRACTOR PULLING.
I READ ABOUT HOW IMPORTANT THE TRACTOR IS BALANCED OUT. I AM PULLING A JD B IN 4500#AND 5500# CLASS. DOES IT MAKE A DIFFERENCE IF THE WEIGHT IS LOW OR HIGH IN THE FRONT OR REAR. OR IN THE MIDDLE OF THE TRACTOR?. HOW SHOULD THE HITCH BE POSITIONED?
THANKS FOR SHARING YOUR EXPERIENCE.
laipuller45
01-09-2002 20:33:47
 Re: WEIGHT? in reply to JACK, 01-09-2002 18:51:47
it's kinda trial and error the first few times. some people disagree with stripping a tractor down, but you want as much movable weight as possible. check your local rules as far as weight placement. usually 16" from the front of the tractor or 11' from the center of the rear axle for front weights. i would reccomend a mid mounted belly bracket and general rule weights do not stick out past the rear tires.
