JD 60 stroke
IRISH RED
10-13-2004 14:54:26
How much stroke can you have and what rods schould I use planning on 5.750 bore
Drew
10-13-2004 16:53:54
 Re: JD 60 stroke in reply to IRISH RED, 10-13-2004 14:54:26
9.500" is about all you can squeeze in there w/o starting to do really stupid stuff. 9.250" is a lot easier. For rods you can weld a 329 diesel (aka 303 gas) rod to the A rod. Both these rods have a 2.750" big end. Or you could get billet rods made that would be much stronger and have them made to use the 2.750" bearing. For a 5.750" bore, I think there is a Pratt & Whitney aircraft piston available.
JDGnut
10-13-2004 19:08:44
 Re: JD 60 stroke in reply to Drew, 10-13-2004 16:53:54
As Drew said.. for the 5.75 use the Pratt & Whitney pistons... When you buy the pistons also buy the aircraft rods.. weld those to the 359 rods..
JDGnut
Drew
10-14-2004 11:05:20
 Re: JD 60 stroke in reply to JDGnut, 10-13-2004 19:08:44
Schooler welded our last set of rods together and didn't want to use the aircraft rods, but rather A rods w/ the pin end bushed down for the smaller aircraft wrist pin. Whether there is a logical reason for doing it that way, I do not know.
JDGnut
10-16-2004 07:21:40
 Re: JD 60 stroke in reply to Drew, 10-14-2004 11:05:20
Drew.. the only thing I can think of is that the if he used both Deere rods.. they are cast.. the aircraft rod is more of a billet..
JDGnut
IRISHRED
10-14-2004 22:03:06
Thanks a lot for the info now just need to get the crank out and start digging
