Tire swap wanted
tractorptsguy
10-13-2004 05:29:33
I have a great set of 18.4X 38 Goodrich 30 degree cut tires that I want to swap for a simular pair of 34s. Mine are mounted on 18.4 inch wide, light weight wheels. These tires bite great. They're just too fast for my 77. Field & Roads also considered.
Mopower
10-15-2004 06:02:28
 Re: Tire swap wanted in reply to tractorptsguy, 10-13-2004 05:29:33
I have a set of 18.4x34 identical to your 38" and interested in swapping but could never find anyone that wanted to. Mine are like new tread, but rubber is nice and hard. How much tread on yours? I have other 18.4x34 types availiable too. Call anytime at 517-726-0484 or [email protected]. Vermontville, MI
Young Gun
10-13-2004 19:55:16
Does anyone know where a set of 18.4x30's might be at??
Andy2
10-14-2004 19:39:24
 Re: Tire swap wanted in reply to Young Gun, 10-13-2004 19:55:16
I have a set of BFG's 18.4X30 in MN They are in good shape $200
keith /sos
10-13-2004 17:02:37
i have a set of 18.4x34 bfgoodrich already cut i might trade if your tires fit my needs. call me 812-707-9336.
49 MM U
10-13-2004 14:23:18
I know where there are a set of 18.4 34 Firestone All Traction Field and Roads. They are mounted on pressed steel wheels and the centers are pretty much in the middle. The tires have quite a bit of tread on them but that wouldn't matter if you were going to cut them. What do you want for your BF's out right if you dont' like these?
Nate
tractorptsguy
10-15-2004 06:36:20
 Re: Tire swap wanted in reply to 49 MM U, 10-13-2004 14:23:18
Nate,
All things considered, I think my "asking price" would have to start at around $1,000. 1 set of just-right-tires, 1 pair of customized wheels that match the tires,light weight to boot, and an excellant cut job if I do say so myself. Yeah, that'd be about the right place to start.
gm
tractorptsguy
10-13-2004 17:31:07
Nate,
Where bouts are those Field and Roads located?
Gary
49 MM U
10-15-2004 07:06:55
 Re: Tire swap wanted in reply to tractorptsguy, 10-13-2004 17:31:07
Those ATF&R's are located in southeast missouri
Where bout's are your tires with that perfect cut job that I am looking for located?
tractorptsguy
10-15-2004 09:32:48
 Re: Tire swap wanted in reply to 49 MM U, 10-15-2004 07:06:55
Email me and I'll tell you. I'm not all that far away in SWMO.
