Supper All Trac Tires
IRISH RED
10-08-2004 06:11:15
whats your opion on them how do they compare to v-cuts schould a guy hand cut them or send them away to be machine cut
LW
10-09-2004 10:52:29
 Re: Supper All Trac Tires in reply to IRISH RED, 10-08-2004 06:11:15
I ran a set of 18.4 X 38 super all trac. with a 3/4 cleat cuts and they were better on a loose track then other tires but they bit to hard on a tight clay track,all in all I decided that a 151 F&R was the best all around for me, The V cuts work good to and the cleat spacing is about right the super all tracs. were almost like running a double cut they eat up a lot of power to get there traction.
Mike Aylward
10-12-2004 09:51:06
 Re: Supper All Trac Tires in reply to LW, 10-09-2004 10:52:29
The Super All-Traction tires are an excellent tire. They are not horsepower eaters. The reason that people think they eat up horsepower is because they hook and any tire that hooks up needs horsepower. Mike
ChadS
10-12-2004 10:14:59
 Re: Supper All Trac Tires in reply to Mike Aylward, 10-12-2004 09:51:06
I would say they take alot of the shock from a larger torque engine. maybe helps smooth out a harsh torque curve over a hard side walled tire. ChadS
IRISH RED
10-09-2004 22:41:08
how much power do you think a div 3 or 4 tractor would need to be able to pull super all tracs on a hard track thinking of hand cutting them thanks for the reply
LW
10-10-2004 20:43:11
 Re: Supper All Trac Tires in reply to IRISH RED , 10-09-2004 22:41:08
What kind of weight class?
IRISH RED
10-11-2004 21:34:18
 Re: Supper All Trac Tires in reply to LW, 10-10-2004 20:43:11
hopefully 4500 up to 6500 speed limit but I would not mind pulling div 4 once in a while
ChadS
10-11-2004 12:53:30
I am giving a set of 18.4X34 super all tracs a try at 3500lbs in November. Will let ya know how they do. Cant decide to put on on the H, or the 460. either way, trying them out. ChadS
IRISHRED
10-11-2004 21:38:30
 Re: Supper All Trac Tires in reply to ChadS, 10-11-2004 12:53:30
are you pulling in Columbia I am planning on trying 18 4 38 down there see what happens
ChadS
10-12-2004 08:59:48
 Re: Supper All Trac Tires in reply to IRISHRED, 10-11-2004 21:38:30
No, Princeton indiana, USAP nov 27-29 I belive. I think they should work,, got a good bar on them, just have to keep an eye on the air pressure closely, the sides are very soft, flexable,, so gotta watch em so they dont buckle too much. ChadS
