upping bore oh 560 d
lloyd powell
10-07-2004 14:45:46
Chad s this would be a good one for you. or anyone else who might have done this. I have a 58 560d and it needs new rings (got blow by) what can I do or how do I put in a 301 piston kit. I understand it will give a total of abt 90 HP. is that true or just hog wash? pls e-mail me and give your pho no and I will contact you if you wish. Thanks LLoyd
trak560
10-10-2004 19:13:05
 Re: upping bore oh 560 d in reply to lloyd powell, 10-07-2004 14:45:46
id try to figure out on how to hold a head gasket because it will leak. you might be looking at putting bigger head bolts in.
Farmall Daddy
10-10-2004 17:47:38
I have a 560 gas that I am rebuilding, and I have estimated it to be around 75 horsepower when I get done with it. Since you are only running the 1800 rpm's, that is where is will hurt you on the power. The 806's ran around, I think 2400, so I would estimate low to mid eighties w/ the 301 kit, and the pump turned up a bit. Best of luck with it!!
ChadS
10-08-2004 07:53:23
I would step up to the 291 kit. For the cost of a rebuild, would be a good economical upgrade to the 560. Years ago, dad had bought a hopped up 560D, at one time it had a turbo on it, but had been removed. it was a 291 engine kit wit the pump turned up a bit. would pull 4-16 plow in 3rd with the TA forward easily in good soil. If you can, step up to a later model engine camshaft, and maybe go through the injector pump to make sure it is up to snuff. ChadS
