Farmall ring and pinion
Firefarm
10-06-2004 14:25:53
Looking for a ring and pinion that will speed up my 560. I am currently running in 3rd and 4th at 5700# with a small block chevy turning 7500 RPM"s. Would like to speed it up so I wouldn"t have to use 4th gear. Anybody have any suggestions?
560man
10-10-2004 18:19:32
 Re: Farmall ring and pinion in reply to Firefarm, 10-06-2004 14:25:53
use a 450 pinion shaft and your 560 gears they all have 49 tooth ring gear this will give you what you want the 560 has a 15 tooth pinion. 560 utility has a 16 tooth pinion, and the 450 19 tooth pinion
turbo 560
10-09-2004 12:35:22
try the utility 560 ring and pinion
AC
10-07-2004 07:32:19
Run an M rear end with a w6 rear ring and pinion....
Wardner
10-07-2004 22:27:31
 Re: Farmall ring and pinion in reply to AC, 10-07-2004 07:32:19
If you want to keep the original 560 trans/axel case, you can install the SMTA, 400-450 gear set. I did the opposite on my SMTA to slow it down. The 560 gears installed in the earlier tractors slow them down by about 4-5 mph in road gear. Email me for a price on my surplus ring gear/mainshaft.
ChadS
10-08-2004 07:59:34
 Re: Farmall ring and pinion in reply to Wardner, 10-07-2004 22:27:31
A utility ring and pinion would speed it up too. it is the same thing as swapping the M- with a W6 ring and pinion. Might drop you back to 2nd, or 3rd easily. ChadS
