Winter Puller Projects Anyone?
Mopower
10-06-2004 08:25:56
Ok, following the conclusion of most outdoor pulls for the season, does anyone have some cool new puller projects lined up? It would be nice to hear what folks are turning wrenches on this fall and winter to bring out in the spring.
buickanddeere
10-09-2004 21:20:18
 Re: Winter Puller Projects Anyone? in reply to Mopower, 10-06-2004 08:25:56
70 Deere LP for the 6500lb but likely the 8000 lb class. Stock antique or what ever they call division I. The two 840 Deere two cylinders for the 10,000 & 12,000 classes are going to be a while. Would like to continue the projects but vehicle repairs and home repairs keeps draining the budget. Now the wife says she want's to take a vacation in Jamacia this winter.
ChadS
10-08-2004 07:56:03
Mopower, got a few going on here. My 460, JD 730G, the ZAU, and going through Something Wilder one more time before the big pull. Got lots to do!! ChadS
1066
10-07-2004 18:31:32
671 for my 10. have 2 deeres at 680 spanking us ih guys my 466, buddies 622, on other at 600, and the rest at 540's. have to beat the green ones.
JDB49
10-06-2004 23:41:52
trying to wake up a john deere 49 B and keep it under 3500 lb. Already punched 125 over, A carb. and alot of head and block work. any other ideas?
Allis Puller
10-06-2004 22:07:21
I'm building an 870 Case, but my wallet is getting thin with this diesel stuff. I hope to have her smokin by spring. I also purchased a MM 5-star but am undecided on what to do with it.
Redman
10-06-2004 19:18:11
plan to poke and stroke it a little bit,i was thinking around that 570 area.
bigger charger,and find about 400 lbs of excess weight to lose.
that is the plan,but the plan does not normally work out like it does on paper!
i wonder if anyone else has that problem.
JDGnut
10-06-2004 19:04:23
Maybe... Finally... get the G finished... and get started on the A... Maybe a tune up for Dad's WD45D.... JDGnut
Augie
10-06-2004 18:41:41
Brakes, diet and some motor upgrades for Rozie.
Replace the tranny input shaft bearing and some minor motor upgrades on the VACuum.
Paint the durn farmall.
KEV
10-06-2004 18:10:57
600 C.I. W-9 International
BUD BARENIE
10-06-2004 18:01:36
MOPOWER
GOT A MOINE G THAT'S LOOKING FOR A NEW HEART !
THINKING 4.75 X 7 BUT JUST THINKING !
HOW DO I GET AHOLD OF YOU !
BUD BARENIE 219-716-0467
E-MAIL [email protected]
joecool
10-06-2004 16:19:04
504 turbo into a case 930 western comfort king also help dad with his 31 case C orchard, plans to install 4 inch pistons, shave a dc head and try to keep under 3500.
oh yeah, freeze in a few Christmas parade's
Lamont
10-09-2004 02:44:53
 Re: Winter Puller Projects Anyone? in reply to joecool, 10-06-2004 16:19:04
How hard is it to bolt up a 504 to a 930 Case? I'd like to do that if it's not a huge project.
Thanks,
Lamont
52 A Boy
10-06-2004 14:35:07
1941 B, boring it .125, with pistons, and a little head, work and hopefully be able to get it in the 3600# class.
JDGnut
10-06-2004 18:56:25
 Re: Winter Puller Projects Anyone? in reply to 52 A Boy, 10-06-2004 14:35:07
52 A... drop GPower or I a line before you get started.. I have some ideas for you.... JDGnut
Sambo
10-06-2004 14:29:37
1939 John Deere B boring it to 125 over then gonna get a hot mag for it and a big nut carb
buickanddeere
10-09-2004 21:24:39
 Re: Winter Puller Projects Anyone? in reply to Sambo, 10-06-2004 14:29:37
Sorry the big nut carb won't get enough airflow/pressure drop across the verturi to control fuel flow. The stock "A" carbs are way plenty for the wildest bored and stroked high rpm B. Go with a cam, compression and some port/valve work instead of the big nut.
Dick L
10-06-2004 14:04:45
I will probly do what I did last wiinter. Walk out to the shop and tell myself If it was just a little warmer I would start rebuildiing one of my tractors. Go back ina house and watch Fox News or C Span. then in a coupla days repete the same process. Three days before the first pull ina spring I will start a three week project and not get it done in time for the pull in the three days even though I miss goin to work and work half the nights. Won"t be able to go cause the tractor is still all over the floor.
Just seems what old is startin to do.
Dick L
10-07-2004 06:40:01
 Re: But This Little Project in reply to Dick L, 10-06-2004 14:04:45
Will probly get done sometime this fall or winter.
AC
10-06-2004 13:51:03
Going to see how much aluminum I can cobble up to fit on one farmall H. Maybe build a Moline R for 3500 farm and field, or see if a 445 motor fits in it. BTW, Mopower, where are you located? I am east of Benton Harbor....AC
Mopower
10-07-2004 04:52:56
 Re: Winter Puller Projects Anyone? in reply to AC, 10-06-2004 13:51:03
I'm about 30 mi SW of Lansing in a town called vermontville. It's near Charlotte and Hastings. My little sis lives in St. Joseph. A good fried of mine builds M-M motors in Kalamazoo. I get back and forth with him for parts. E-mail or call anytime. I have an R pullere in my garage that is almost ready to make its debut and it should be strong.
Ethan Berry
[email protected]
517-726-0484
AC
10-07-2004 07:43:48
 Re: Winter Puller Projects Anyone? in reply to Mopower, 10-07-2004 04:52:56
Yeah, I used to run chemicals up there when I worked for Helena. My best friends family lived in Hastings, so I am somewhat familiar with the area.
Not trying to be presonal here, but about 4 months ago, I met a girl who said her brother or dad, (I don't remember) pulled tractors. (I had mine on the trailer), pulling into the restaurant/bar. I wonder if it was her...?? Ironic,if it was...I think she was about my age, or 23 or so...huh....wierd...I live right by St Joe, in Coloma. I'll have to take a ride up and see that R..... AC
Mopower
10-07-2004 08:07:37
 Re: Winter Puller Projects Anyone? in reply to AC, 10-07-2004 07:43:48
If it was a nice looking dark haired girl, it could have been. She is 22. She works for an advertising place that does work for Whirlpool. Dad and I both pull together. Come on up sometime. My friend Cheryl Bates grew up in Coloma.
AC
10-07-2004 08:44:59
 Re: Winter Puller Projects Anyone? in reply to Mopower, 10-07-2004 08:07:37
I really didn't think she had dark hair, but I do remember that she was sharp! haha, not trying to talk about your sister, if it was, but you know... ANYWAY, Bates...that name sounds familiar. What year did she graduate, and is she about 26?
I quit running around with most people from Coloma when I was about 19, so, I have forgotten ALOT of names, but I remember some faces.
I think my neighbor works for the same company. Ask your sis if she knows Kathy Brutchee (sp?)She works/worked for an advertising company that did stuff for whirlpool but I never knew the name.
Where are you going to debut this R? and, who do you pull with? later, AC
Mopower
10-07-2004 08:58:04
 Re: Winter Puller Projects Anyone? in reply to AC, 10-07-2004 08:44:59
Cheryl Bates must be about 30 but she has a younger sis that is my age I think. Redhead named Melanie. I'll mention it to my sis. I pull with Clintonia Pullers around Lansing. Fowler is our home track. A lot of tough competition in that club. Not sure when it will debut. Needs a hitch and sharp tires as well as a tuning, break-in, and wiring. E-mail me at [email protected].
Jak
10-06-2004 12:06:54
When I get a customers G and A John Deere restored then I'll start on the Super 88 Oliver.I am looking into fabricating some new wheelie bars and weight brackets as well as electronic ignition.If I have enought time and funds I would like to freshen up the engine and do a little porting work on the head.How bout you Mopower,what you got planned?Jack(TN).
Toot
10-06-2004 14:00:28
 Re: Winter Puller Projects Anyone? in reply to Jak, 10-06-2004 12:06:54
You need to trade him the super for the G you're working on. Don't you miss the thud thud?
Jak
10-06-2004 14:16:56
 Re: Winter Puller Projects Anyone? in reply to Toot, 10-06-2004 14:00:28
Oh I do miss that sound but he won't part with his G for nuthin,he really likes it.He has several Olivers,John Deere,Minnie Mo's and Farmalls already but that is his one and only G exept for his G Allis(but that don't count ha ha).I'll get another JDG someday but I am really liking the 88 right now,it balances real well and has good power.Have you got any pics of the unstyled G yet,I'd like to see it?Jack(TN).
Jeff Oliver
10-06-2004 14:05:24
naw old Jak there is enjoying winning alot now. Even more than when he had the G it think. hehe besides he gets to pull against ME now ! LOL!!!!!
Humm freshening the engine huh????? Don't make me have to add a bigger squirrel cage to mine....., got two critters in there now am I gonna have to make it three?LOL!!!!! hey jax, figure out what you want on the wheelie bars, I might be able to help you out there.
Jak
10-06-2004 14:26:38
 Re: Winter Puller Projects Anyone? in reply to Jeff Oliver, 10-06-2004 14:05:24
Need more room for weights behind the tractor and was wanting a stronger set of bars with brackets on them also.The ones I currently have were a quick fix in a hurry and you can tell it by looking at it too.So far I haven't gotten on them but one day I might get hooked to one of those sleds that just drop all the sudden and wham up she comes QUICK!That happened to me once at Missouri(on the G)and when it did it hit so hard it unloaded the tires and there it was.
Mopower
10-06-2004 12:19:34
Mostly finishing projects on the backburner. My 1939 M-M RT puller need wiring, starting, and break-in, not to mention some good details. My UTU needs a motor swap to get running again and I have a Twin City JTU that I may bolt together without modification just to be able to run it around. But then there is a GBD, 335, and 5-Star coming for who knows what. Dad has a UTU and UBU to tweak and two KTA Twin-Citys coming for who knows what. Busy busy. Just hope to run my RT and UTU.
CASEPOWER
10-06-2004 11:56:25
Try too finish a Case CC and working on a 1922 Fordson 340+ cubes 2500#. I have enough to keep 3 men busy all winter long. I also know of another Moline being built this winter that is VERY BIG!
LW
10-06-2004 17:59:52
 Re: Winter Puller Projects Anyone? in reply to CASEPOWER, 10-06-2004 11:56:25
SSSSHHHHH! Nobody would believe us if we told them!
W-40
10-07-2004 05:45:21
 Re: Winter Puller Projects Anyone? in reply to LW, 10-06-2004 17:59:52
NO, we wouldn't believe you! My IH will stomp any MM from the east coast! I won't sleep knowing you guys are at work!!
LW
10-07-2004 14:33:18
 Re: Winter Puller Projects Anyone? in reply to W-40, 10-07-2004 05:45:21
You need to lay off that stuff if its got you believing that , I myself plan to build a w-40 some day but it will not hang with a 6cyl MM in heavy classes like 8,000 up, if you think it can bring it on down, you'll probably have a good chance at second place.
CASEPOWER
10-06-2004 18:44:36
That's why I didn't post any cubes, because they would say we it was a 6 cyl. forsure.
W-40
10-06-2004 12:30:52
that sounds really scary!! oh my gosh!!
CASEPOWER
10-06-2004 15:45:13
 Re: Winter Puller Projects Anyone? in reply to W-40, 10-06-2004 12:30:52
Blow or Go, it will be fun either way.
Shutt30
10-06-2004 12:10:51
4 or 6 cylinder? LW sell his GB yet?
CASEPOWER
10-06-2004 15:43:30
 Re: Winter Puller Projects Anyone? in reply to Shutt30, 10-06-2004 12:10:51
4cyl. LW still has his GB, I can"t afford it and it is a winning tractor. I know I couldn"t build one, for what he is asking for his.
donny
10-06-2004 11:00:54
case 930 gas for hobby stock
gee
10-07-2004 05:57:10
 Re: Winter Puller Projects Anyone? in reply to donny, 10-06-2004 11:00:54
i have a big 4 i mite sale like to have a 6 217 997 2280
