Temple, TX Pull/show???
JDGnut
10-01-2004 21:12:29
third party image
We took 3 tractors down to Temple this evening.. All looked good.. I thought I'd post a pic or two.. since we have had over 1 inch of Rain since we got home tonight.. Looks like its going to be geasey tomorrow.. I'm trying a different (short) tires for this Run-what-U-Brung class.. I need the extra gearing.. since it is an Unlimited weight class... (I'll get smoked.. but we'll be there... )(only adding 4500lbs... that's insaine.. )
Anyone else going to make it????? JDGnut
DP
10-01-2004 21:59:21
 Re: Temple, TX Pull/show??? in reply to JDGnut, 10-01-2004 21:12:29
Lookin Good there JDGnut! Is that the one you been building? Been promising myself I'm going to get back in the action, but looks like I missed this year.
JDGnut
10-02-2004 06:47:38
 Re: Temple, TX Pull/show??? in reply to DP, 10-01-2004 21:59:21
Nope.. that's The ol Clunker I've I been pulling.. I just changed tires for this pull.. I had this set of 34in Metric Radials sitting.. Ok going to give them a try.. At this pull they divid you into Hp by stock HP.. and then unweighted.. and weighted classes... weighted meaning.. as much weight as you can get on the tractor.. Even with the 4500lbs my tractor won't be over 10K... Its those pesky A's with the creaper gear that kick me at this pull..
JDGnut
(DP what email address are you using.. I've got a pic or two I need to send you..)
JDGnut
10-02-2004 23:50:02
 Re: Temple, TX Pull/show??? in reply to JDGnut, 10-02-2004 06:47:38
third party image
Dang, was it muddy.. after a few hrs of them trying to dry out the track a little.. the hooked a few about 4:30... No classes.. just hook and go... Little tires didn't go far... just gummed up... should have left the big shoes on... I left a friend make the only pass... (if you want to call it that..) JDGnut
DP
10-03-2004 12:48:09
 Re: Temple, TX Pull/show??? in reply to JDGnut, 10-02-2004 23:50:02
Hi JDGnut. Just got back in from a wedding down at Great Bend. Had some frost around in places saturday morning. E-mail address since we moved a couple years ago is [email protected] Well, being gone for a couple days, so I'd better get out and get busy.
