OLIVER 88, S88, 880 deck height from ctr of crank
Torquenut
09-29-2004 08:26:30
Does anyone know the distance from the center line of the crank shaft to the top of the cylinder deck on an Oliver 88, S88 or 880?
Anyone have one currently torn down they could measure? Thanks in advance.
Torquenut
oliver puller 2
09-29-2004 17:18:30
 Re: OLIVER 88, S88, 880 deck height from ctr of cr in reply to Torquenut, 09-29-2004 08:26:30
it should be right about 11.o depending on whether you have had it resurfaced, etc. email if i can help. i do have some great pulling carbs if you are making more cubes good luck with your project
torquenut
09-30-2004 04:33:09
 Re: OLIVER 88, S88, 880 deck height from ctr of cr in reply to oliver puller 2, 09-29-2004 17:18:30
Oliver puller 2, drop me a line... would like to talk.
torquenut
tractor pullerks
09-29-2004 20:11:06
what do you have for carbs for sale and how much
oliver puller 2
10-01-2004 22:03:50
 Re: OLIVER 88, S88, 880 deck height from ctr of cr in reply to tractor pullerks, 09-29-2004 20:11:06
i have some new old stock zenith that are bigger that a 1650 carb that i can customize to your application...these carbs will work on oliver MM Massey .....also have 88 and 1650 rebuilds ..... ..will work on your exsisting carb if you like email or call [email protected] 217 826 6198
