Light weight steel rims
Shutt30
09-28-2004 19:39:59
I am looking for a set of lightweight 13" to 14" wide 38" steel rims. Any one know where to find a used set and how much? Thanks
ChadS
09-29-2004 10:34:05
 Re: Light weight steel rims in reply to Shutt30, 09-28-2004 19:39:59
Shutt 30, Do you have any of the old coop/ cockshutt pressed steel centers? I had a set, that I welded the center lugs to the rim, and used oliver 770 rims, and bolted the cockshutt centers to them. Pretty light,, Might help narrow the search a bit for some parts! ChadS
Shutt30
09-29-2004 12:39:13
 Re: Light weight steel rims in reply to ChadS, 09-29-2004 10:34:05
got the centers but some people were telling me about lighter steel rims being made. I have M & N pressed tin right now. Can"t afford aluminum.
ChadS
09-30-2004 08:40:23
 Re: Light weight steel rims in reply to Shutt30, 09-29-2004 12:39:13
How heavy of class do you pull in? If you got the centers, aint hard to make a set. I have the specs for the cockshutt lugs, that bolted to the rim, easy to make out of angle iron, or kinda like a spoke that goes to the center. The cockshutt centers, are pretty light, but could handle a heavy class, some of the older pressed steel rims, were lighter material, in the centers but they flex alot at the 9 bolt pattern. I can show a picture of a set of rims we made with the cockshutt centers, cheap set, yet very light, and strong. ChadS
Shutt30
09-30-2004 19:00:39
 Re: Light weight steel rims in reply to ChadS, 09-30-2004 08:40:23
3200# at the lightest. I can make it now but would like a moveable weight. I was told that someone was building light weight steel that are 40# lighter per wheel than the old M&W's. Can't afford aluminum. I run the old type of M&W's right now.
