Question On Building a MH44
JWegener
09-27-2004 14:43:18
I am Building a Massey Harris 44 and would like to know how big I can bore it still using a wet block. I would also like to stoke it as much as possible does any body know how big I can go and how much hp I can Produce. Thanx
Masseypuller
09-28-2004 06:09:39
 Re: Question On Building a MH44 in reply to JWegener, 09-27-2004 14:43:18
I am running a 5" bore with a full water jacket, but this takes a lot of work! The block can be bored to 4.5 or 4.625 without any offset to the bore centerlines. As you can see, you can go much bigger with offset. The biggest stroke to run with stock rods (and reasonable clearancing) is 6.25". 7.5" stroke will fit with the right combination of rods and clearancing...
Regards,
Masseypuller
[email protected]
MH49
09-29-2004 04:58:45
 Re: Question On Building a MH44 in reply to Masseypuller, 09-28-2004 06:09:39
Are there any off-the-shelf sleeves that can be used to get the 4.5 - 4.625 bores?
ChadS
09-27-2004 17:28:37
Seen an article in the hook a while back that stated 7 inch stroke in a 44. Seen a 500 inch 44 That pulled wit the Tuggers about 3 years ago, impressive!!! ChadS
