checking stroke and compression on M
M guy
09-24-2004 04:08:55
is ther a way that I can check the bore and stroke of my M without removing the head and pan? I think that I may have a m&W crank in my old M also what would I have for cylender pressure if it had M&W pistons? TIA
ChadS
09-25-2004 07:26:53
 Re: checking stroke and compression on M in reply to M guy, 09-24-2004 04:08:55
Run a compression test on it. check the head casting number. Look at the block # too, maybe someone swapped the ol m engine out with a later engine. if the compression is very high, might have one in it.
