Piston size and stroke for John Deere
jimbo
09-22-2004 18:30:40
How much power will I get from a styled crank and a big bore in a unstyled A. I need to get about 50 hp to pull in 5000lb class . Need to know what to do, what head, what piston, block and crank. Do I need to stroke the crank, or can I get by with just a big bore like a G piston. Thanks.
Toot
09-22-2004 21:04:43
 Re: Piston size and stroke for John Deere in reply to jimbo, 09-22-2004 18:30:40
If 50 is all you want, bore to 5 7/8" which will accept the 70 gas piston, also, you will have gained a 1/4" stroke by using a 41-46 crank, with a gas style manifold, a little head and carb work, you should be there.
