tire pressure/ spin on rim
tsc
09-21-2004 23:02:47
I have a ca Allis stock i pull with a set of uncut 11.2-24 goodyears. What is the least air pressure I can run with out spinning them on the rim?
Thanks for the info
colekicker
09-22-2004 20:34:55
 Re: tire pressure/ spin on rim in reply to tsc, 09-21-2004 23:02:47
Depends on how hard the tire is, how long it has been on the wheel, if it is a newer tire what lubricant if any had been used in mounting. Lots of variables. Remember, too little air pressure will cause a cupping action in the center of the tire you can't see. Also, hitch height can drop when the load from the sled comes due to tire squat. Air pressure is the key to winning. You can have the greatest engine in the world, but it does no good if you can't get the power to the ground.
