ChadS
09-22-2004 06:39:43
Re: Question for dead weight pullers in reply to ACWC, 09-22-2004 05:50:23
ACWC is right, you do have to hitch up at an angle to the sled, best advice on that part, is when you back it in,, keep the hitch aligned with the pin on the chain on the sled, you need to make sure the frontend, the rear end, and the hitch, is pretty straight with the chain, and the pin that hooks the chain to the sled. A massey 44, well it will have to be a bit heavy to achive the proper balance, weights behind the axle, that acts as a counter balance, to put the front end up in the air at take off. We are able to use duals, but a new set of 18.4X34's work well too. Use a softer tire, the newer the better in my opinion, hard tires, just dont seem to hook as well on asphalt, or concrete over a new tire. If the club hosting the pull, has no hitch specs,, get the hook point as close to the rear axle as you can. Hope this helps a bit. ChadS
