Question for ChadS about IH carb
jakeK
09-21-2004 19:52:34
I read your info about rejetting the IH carb,
would the same thing work for a John Deere
with MS carburetor? If you could offer any
advice it would be appreciated
ChadS
09-22-2004 07:34:41
 Re: Question for ChadS about IH carb in reply to jakeK, 09-21-2004 19:52:34
What are you working with? Best advice I can give at this time, is to look carefully at your head, and the spark plugs. If you can work the engine, and then shut it down, and check the plug color, that will tell you if you you need more fuel. Run a compression test, if it from 100-150 psi, then you may get away with a jet change. if it is over 150psi, then there is a few more factors to carefully look at. Whiteish plug color, it is too lean, not enough fuel, brown plugs, it is really close, and if they are black, too much fuel. ChadS
jakeK
09-22-2004 19:12:22
 Re: Question for ChadS about IH carb in reply to ChadS, 09-22-2004 07:34:41
Thanks for you reply. I have a JD 1520 tractor
with a Marvel-Schebler TSX-944sl. The tractor is mainly a chore tractor, but I used it some this summer to bale round bales, it didn't do to bad,
but in some heavy hay, it pulled it pretty hard.
I'd also like to pull it at a few local pulls
nothing real serious. I feel like my compression
is good but I haven't tested it. The plugs are
white on the ends of the electrode with a little
bit of black soot on the bottom of the plugs. The
engine has about 1100-1200 hrs since it was overhauled. If I could pick up just a few extra
horsepower it would be real handy, but I don't
want to spend a lot money to get it. If there's anything else I could do or should look at let
me know. Thanks for the help
ChadS
09-23-2004 12:43:42
 Re: Question for ChadS about IH carb in reply to jakeK, 09-22-2004 19:12:22
Sounds like you can give it a jet change and give it a few more HP. At loaded rpm, it is not getting enough fuel to run the way it should. Still set up for economy a bit. All these old carbs were under jetted, yet was just enough to let them run. If I am thinking right,, they had this same carb on the ol eb45 combines. The plugs tell the tale right there,, not enough fuel. Now, on these carbs, they are a bit different than the IH sheblers, but still can be rejetted, I think these carbs have a removable main jet, (Like a Holley carb jet) and would be easier to do, if you can get the jet out. Simple way to test, if it does need more fuel, is if you can take the main adjustment (fuel) and open it up, and the engine should run richer, or barely start to flood itself. if not, probably go up 2-3 sizes on this carb jet. ChadS
