stroke
Champspa
09-21-2004 14:18:11
Hey Chads, how much can you stroke a 450 without to much trouble ?
BUD BARENIE
09-24-2004 16:55:13
 Re: stroke in reply to Champspa, 09-21-2004 14:18:11
O.K.
I'M GOING TO TAKE YOU UP ON THIS ONE !!!
ChadS
09-22-2004 06:48:32
6 inches, you will have to grind the rods, a few spots in the block, and inbetween the cam lobes, that is using stock rods too. Not alot of grinding in the block, not a difficult task. as for no block grinding, 5-3/4 just rod, and cam grinding a bit. ChadS
champspa
09-22-2004 15:36:21
 Re: stroke in reply to ChadS, 09-22-2004 06:48:32
what do you think 5.75 would do for a 450 with 70hp and 205 cylinder pressure?
ChadS
09-23-2004 07:35:12
 Re: stroke in reply to champspa, 09-22-2004 15:36:21
Rough estimate, it may have 225-250 psi, at 225psi,, 80 hp, at 250psi, 90+hp. ChadS
champspa
09-23-2004 15:03:25
 Re: stroke in reply to ChadS, 09-23-2004 07:35:12
thanks Chad I'll think about it and maybe this winter we can talk about it . I have your number
