Also,,,,,,,
ChadS
09-17-2004 09:52:43
What about the location on the front axle as far as wheelbase is concerned? At the moment, it is as far forward as it can be in the frame rails.ChadS
Dick L
09-17-2004 13:12:06
 Re: Also,,,,,,, in reply to ChadS, 09-17-2004 09:52:43
Why not let it pivot and use a pair of coil springs at each side rail to keep the axle level when the front is in the air. The old Ford cars used a single centered leaf spring which would work as well on a solid axle. Back in the late 50"s when I was messin with stock cars I put a single leaf spring along with a ford axle on a 35 Chevy. What a wast of a good Chevy! That was not to keep the axle level but so I could use a jack screw to load one side more than the other on a circle track. I was after just the opposit that you want.
Andy2
09-18-2004 15:00:12
 Re: Also,,,,,,, in reply to Dick L, 09-17-2004 13:12:06
ATV or snowmobile struts on a pivoting axle would work well and look cool.
Chip
09-17-2004 20:47:23
The jackscrew idea would work neat on a puller. Picture this: as you want to turn right the Right front wheel would push down loading the Left rear giving it more traction turning tractor to the right. Got ya thinking !!!! Now put hydraulic cylinders on each side with hydraulic lines connected to the power steering lines???? I"ve been thinking again Sorry!!
