ih 460 gas for pulling
darrin
09-14-2004 11:03:10
Are the blocks the same as the 301, would I be able to bore my existing block or better off getting the 301 and boring that. want to bore to 4". I would have to buy a 301 so using my existing block will save money as long as the end result can be the same.
ChadS
09-15-2004 08:04:28
 Re: ih 460 gas for pulling in reply to darrin, 09-14-2004 11:03:10
Look around for an IH grain truck that has a 6 in it. Good factory performance parts there if built right. Truck IH 6 cyls have a high compression head over the tractors, have to use flat top pistons with it, but will build alot of compression. ChadS
460
09-14-2004 20:01:01
have a 301 in the shop no head you want it make offer
darrin
09-15-2004 06:00:59
 Re: ih 460 gas for pulling in reply to 460, 09-14-2004 20:01:01
where are you located? block,crank and pistons good? any other parts with it? I found a couple complete 301s out of 715, salvage yard wants $750
no manifolds.
460
09-15-2004 09:01:25
 Re: ih 460 gas for pulling in reply to darrin, 09-15-2004 06:00:59
WI and i do think the crank and pistons are good needs to be cleand up a little. have a cam for it want 150 for it. ran it in a 460 puller ground by barry cams. lp intake other misc parts axels with weld on hubs and housings 200.
ChadS
09-14-2004 18:36:04
Yes, the blocks are mostly the same, anything that can be done to a IH 6, can be done to all of them. Yep, a 301 to start with would be cheaper to bore, than any other. Been thinking of the 301 kit for a while for my 460, So many options, what to do????? ?? ChadS
JDGnut
09-15-2004 10:05:48
 Re: ih 460 gas for pulling in reply to ChadS, 09-14-2004 18:36:04
When looking at th SN# tag on the 301-265.. is it clear which engine is which... or is there a casting number??? I don't usually pay much attention to the later red tractors.. but I found an engine.. heads and other parts off... off an old grain truck... Thanks
JDGnut
ChadS
09-15-2004 11:04:31
 Re: ih 460 gas for pulling in reply to JDGnut, 09-15-2004 10:05:48
Casting numbers. is the best way to tell, the tag on the engine is usually found inside the truck in the cab down by the kick panel by the drivers door. Visually, they look different, in a few ways, the firing order is on top of the head on the truck heads, and on the block for the tractors, also, look at the compression chamber, and the valve angle. the truck heads, have a very very shallow chamber, and there is no angle in the valves, where the tractors, have a large chamber, and angled valves. Also the dead give away for a truck engine is the flat top pistons. the SN# on the combine engines usually have the model of the machine it was placed in, tractors have the cubic inch on the block, stamped at the front. not too sure on the trucks on the block for numbers,, like I said, they had ID plates inside the truck. Also the truck/tractors/combine blocks and heads had different casting numbers, not listed together. ChadS
JDGnut
09-15-2004 11:58:29
 Re: ih 460 gas for pulling in reply to ChadS, 09-15-2004 11:04:31
Thanks.. is there a listing on the web of the different numbers??? The trucks were sold years ago.. I have no idea what is really there.. I didn't have to to dig though the parts.. I'm not even sure it was an IH... but I will look closer next time I get a chance to get to the parts again... JDGnut
Buzzman72
09-16-2004 04:59:18
 Re: IH 6-cylinder truck engines in reply to JDGnut, 09-15-2004 11:58:29
On most of the 6-cylinder IH truck engines, the model and the serial number are usually on a machined spot on the passenger side (that's the RIGHT side, for you 100% tractor folks)of the block...top of the block, just below the head, in front, just behind the water pump...can't miss it.
ChadS
09-15-2004 12:55:53
 Re: ih 460 gas for pulling in reply to JDGnut, 09-15-2004 11:58:29
Buzzman72 helped me on that one, here is the site where I found most of the info, ChadS
