FALLL INDOOR PULL AT THE MOTOPLEX @ LOATTO, IN
Laotto Helper
09-06-2004 10:41:57
Josh and I and all of our helpers would like to invite you all to the Fall Indoor Pull Oct 22-24. This year we will be running all of the same classes with the change of Div 2 which we will be allowing top dressed tires and following our general rules for motors and tractors. Our local rules div 3/4 will be the same as last time and all of our div 2 will run all day Sat Oct 23. Trucks at night. We will have an ad in the Hook Magazine with all of the classes, and if you want to see pictures and results from the last pull go to WWW.themotoplex.com.
Thanks again to ALL the pullers that supported us the first time around. We hope to make this pull even bigger and better!!!!
Thanks again
Laotto Helper and Crew
