Farmall M
Just gettin' st
09-04-2004 02:49:52
I am interested in building a Farmall M to pull. I have heard a lot about making them faster with other Farmall rear ends and transmissions.Any advice?What parts? Thanks.
country boy
09-09-2004 16:00:38
 Re: Farmall M in reply to Just gettin' started, 09-04-2004 02:49:52
My experience has been the gearing is fine . The main thing you need is more cubic inches. Find yourself a reputable machine shop that has experience in such things and bore and stroke that engine as much as your pocketbook will allow.Adding stroke gives you more lugging power. Ever wonder why those Deeres' are so tough? It's the stroke! I've been pulling a M for about 4 years now. I took it out to 500 cubic inches with 18.4-38's on it. Awesome combo! I can pull with all the big tractors clear to 8500 class no problem. The main thing on the crank is make sure the rod journals are beefed up good enough to take it. When I first built mine, I purchased a crank that was already stroked and had the rods turned down to the size of a super C bearing. It ran almost a year like that before I broke the crank. Nothing like doing something twice! Beefed it up, [new crank, of course] now it's tougher than ever. I got another 1/4 inch of stroke the second time.I'd be glad to help if I can. Good luck.
Jason(PA)
09-04-2004 13:45:26
I would just go out there and start to learn the basic things like getting it ballanced,tire pressure,hitch height,gear,etc. Then you can work on it from there.
DCTOM
09-04-2004 17:31:22
 Re: Farmall M in reply to Jason(PA), 09-04-2004 13:45:26
very good advice, every time they drop the hook learn something
