IH 466
Chris
09-02-2004 09:33:54
What is the procedure to make a IH 466 up to a 505 cu in. I heard it was fairly inexpensive but i need advice on what to do.
Thay
09-11-2004 09:23:50
 Re: IH 466 in reply to Chris, 09-02-2004 09:33:54
To make a 400 series IH into a 505 cubic inch motor you need a block bored to accept Case 2590 sleeves (4 5/8 bore) but instead of a 466 crank to make a 540 you use a 436 crank to net 505.
Redman
09-02-2004 11:12:47
case 504 sleeves and pistons will get you 540 cid.
sleeves have to machined so the o-rings are in the right spot and the block must be machined to fit the sleeves.
Chris
09-02-2004 18:25:47
 Re: IH 466 in reply to Redman, 09-02-2004 11:12:47
Thanks Redman, Do you know of a convienient place to find these or just recommend going to a dealer?
dogg
09-03-2004 12:55:56
 Re: IH 466 in reply to Chris, 09-02-2004 18:25:47
go to a tractor bone yard. they should have used parts. but get new rings. i would use a 467 roller cam truck block.
540
09-05-2004 06:33:00
 Re: IH 466 in reply to dogg, 09-03-2004 12:55:56
i have a 400 block punched out for a 540. i also have 5 sleves and 5 pistons.
