Tube Front end for 6500 to 9500 lb. tractor...
MH55
08-31-2004 11:00:42
Just wanted to get some opinions on wall thickness for the axle I'm building for my 55. Using 44 standard kingpins and knuckles. The 44 axle is 2x3 solid stock. I'm going to cut off the kingpin ends and weld them to a length of 2x3 rectangular tube, to stretch the width of the axle and save some wieght. How thick should I go to keep this from bending in the middle. I realise that if I'm careful and don't bounce the front end I could go thinner, but I want to build this once and only once... All opinions will be appreciated.
Derrick Otis
Redman
08-31-2004 20:17:30
 Re: Tube Front end for 6500 to 9500 lb. tractor... in reply to MH55, 08-31-2004 11:00:42
if you want it light and you want to do a little extra work go with 1/8 inch tube and cut one side off and run some 1 3/4 inch moly tube inside like this /\/\/\/\/\ if you don't want to do this,the 1/4 inch is the way to go.
CASEPOWER
08-31-2004 12:45:35
I"m with FARMALL, 1/4" at the least. Seen 1/8" bend in 4500# class. I use 3/16" for the ones I have built, but pulled 3500# and down. The way it works the top will crush long before the bottom stretches. It wouldn"t hurt to run a extra plate on top.
FARMALL
08-31-2004 11:59:11
I would use 1/4" wall tubing.
