5020 engine rebuild
Johnboy
08-30-2004 22:47:24
Just bought a 5020 with a spun rod bearing getting ready to rebuild it would like some more horse power. I plan on using some for pulling and field work also. The tractor already has a turbo added any info would be helpful.
JDGnut
09-01-2004 13:39:15
 Re: 5020 engine rebuild in reply to Johnboy, 08-30-2004 22:47:24
If you are going to replace the block.. do as B&D said.. or at least look for a 531 P-pump block.. the mounting is different on the block for the different pumps.
JDGnut
buickanddeere
08-31-2004 05:51:43
Bolt in a decent 619 from a 40 or later series JD
