aluminum wheels on front of UB moline
family traditio
08-24-2004 19:26:55
What is the best way to mount aluminum wheels on front of a UB? Is there a hub made that will fit the original spindle? Is there a set of spindles off of another kind of tractor that will work? Or, do ineed to get a set of hubs and have my spindles machined to fit them?
JDGnut
08-25-2004 09:06:09
 Re: aluminum wheels on front of UB moline in reply to family tradition, 08-24-2004 19:26:55
Just curious.. what is the bolt pattern on the MM's???
JDGnut
family tradition
08-26-2004 05:42:04
 Re: aluminum wheels on front of UB moline in reply to JDGnut, 08-25-2004 09:06:09
It looks to be 6" on 5", typically, 6 lug trucks are 6" on 5.5", correct me if I am wrong
MIB
08-26-2004 10:01:30
 Re: aluminum wheels on front of UB moline in reply to family tradition, 08-26-2004 05:42:04
We have been using space saver spares out of the 87 or so ford thunderbird. It was an option and are kind of hard to find. They have a large flat center and you can bore out the center and redrill the bolt patter to fit the small U hubs which will fit the ub spindles.
Mopower
08-27-2004 12:28:06
 Re: aluminum wheels on front of UB moline in reply to MIB, 08-26-2004 10:01:30
Do small patter hubs of the old ZT tractors fit UB spindles as well. ZT and R models had the small pattern. If not, do the spindles fit the same spline shaft in the front end? Mystery I"ve wondered about for years.
Ethan
