best 6500-9500 6cyl Minni Mo
Jon88
08-24-2004 13:27:26
What would be the best 6 cylinder Minniapolis Moline to pull in classes 6500 to 9500. I"ve seen a couple of GVI"s. What do yo guys think.
DANNY HOGGE
08-25-2004 15:25:52
 Re: best 6500-9500 6cyl Minni Mo in reply to Jon88, 08-24-2004 13:27:26
I HAVE A GVI FOR SALE . I ALSO HAVE A 800 HD WITH THE PROPER FLY WHEEL AND EVERY THING TO PUT IT RUNNING . THE 800 HAS BEEN JUST OVERHAULED WITH ALL NEW PARTS WITH .040 NEW PISTONS AND ROD BEARINGS. MAINS DID NOT NEED REPLACING , THEY WERE LIKE NEW . ENGINE IS SET UP FOR GAS OR PROPANE WITH 10.4:1 compression ratio. If intrested give me a call @843-332-3566 or e mail TX, DANNY H
Rich B
08-25-2004 10:03:36
GVI all the way,we have one on lp pulls awesome 6000 and up. Rich
A.P.
08-25-2004 10:00:38
It all depends on what the rules you are going to run under allow. I reccommend using whatever tractor model allows for the most rpm's if they are regulated. Thisd usually means a late model tractor. Past that get an 800 and build it up from there if you are looking at a gas/lp motor. Diesel would be another story.
Mopower
08-25-2004 07:49:32
A GB would be your best bet, but be careful. Some rules prevent the use of a 6cyl GB because only the diesels were 6 cylinders. A good GBD with G1000 parts does well, but a 800 or 605 motor on gas or propane can work better if rules allow. GVI were all 6 cyl. Your motor options are endless in MM tractors.
JFK
08-25-2004 07:53:51
 Re: best 6500-9500 6cyl Minni Mo in reply to Mopower, 08-25-2004 07:49:32
G-VI....no question!
