What Hubs will fit on 1947 UTU??
IAPuller
08-24-2004 09:09:48
I've been looking for hubs for a UTU and no luck so far. We was at a pull this weekend and a guy has used hubs off a 4010 John Deere and then used a piece of exhaust pipe to hold the hubs in place? Do you know where I can find John Deere hubs or Moline Hubs or any hubs that will work and the tractor to have 9-Bolt pressed steel wheels.
Thanks!
WTW
08-24-2004 13:53:04
 Re: What Hubs will fit on 1947 UTU?? in reply to IAPuller, 08-24-2004 09:09:48
What is your axle Diameter. A 4010, 3020,3010 and most 4030 along with many two cylinders JD's had a 3.125 diameter axle. A early 4030, 2520, 2510 and 2010 JD has a 2.875 diameter axle. A 2010 uses a nine bolt hub and a square keyway. I do know where there is a set of those in a yard. Let me know if you are interested. (Eastern Iowa) DW
Mopower
08-24-2004 10:23:42
Someone told me Oliver hubs fit with some boring out. Massey 44 hubs may also be close, but better measure for sure!
Ethan
