ChadS
08-22-2004 10:24:02
Re: Tires in reply to Kevin, 08-22-2004 08:39:22
Run em, will be pretty good tire to grab a bite for the height of the tire,,, yeah, you could have went bigger,, but you better be lighter in weight with a low hp engine. Really, if you wanted to spice up your H, put on the big carb and manifold off the super H-350 farmalls, you can use the 350 cam, it will help more too, but pay attention to how the carb is built, swap out the governor spring, ( ihave them if you need one, or 2) distributor,,, rebuild it, run a compression test,, see if all the cyls are close to each other in pressure, that will tell how solid the rings, and valve train is, sure, the pressure can vary, and you can readjust the valve lash to compensate the differences, sometimes, it can even the pressures out,,, increase pressure,, depends on how you tune it, lots say, well cubes is the only way for power,, well true,, but for an engine that is not even close to being peak HP for that engine,, it is all in the engine controls when it comes down to it, there is HP hiding in your H, and can cost less than 100 bucks to pick up 5-7 more hp easily, and not do anything major to the engine. Chad
