Tire questions
Jak
08-20-2004 08:30:42
Which tires hook better,Armstrong or Firestone Field and Roads?Which is favored more 14.9 38's or 15.5 38's?Most of the pulls I went to had a maximum tire size of 15.5 38 from 6000lb and down and from 6500 lb and up can run 18.4 38's.The pull I was at last Saturday allowed 16.9 38's down in 5500.I got a set of 16.9 38 B.F.Goodriches 30 degree I might trade for a good set of 14.9 or 15.5 38's.I currently run Dyna Slips,they gotta go.
nate
09-11-2004 07:10:47
 Re: Tire questions in reply to Jak, 08-20-2004 08:30:42
I would be interested in buying those bf's if you want to sell them... the only 15.5s I have to trade are a set of firestone 45 degrees
2 Cylinder
08-20-2004 19:17:42
Either one of the tires (Firestone, or Armstrong Which are now made by Titan) you have mentioned are very good choices, I have run both and would recommend either one. As for the tire size, most people would recommend the 14.9 x 38's over the 15.5 x 38's because it is a taller tire.
