3500lb 77 oliver
olman
08-18-2004 19:01:28
Will a 1951 77 oliver make the 3500lb class with pressed steel rears, cast fronts and a 200lb driver? Thanks
Rich B
08-19-2004 14:53:15
 Re: 3500lb 77 oliver in reply to olman, 08-18-2004 19:01:28
I pull mine in 3500 open has no PTO hydraulics etc. its a 49 with band brakes.tin wheels all around. I weigh almost 200 lbs. It's a lot of fun!! Rich
one wheel wander
08-18-2004 19:17:07
I pull with A 77 and I know it can be done.
you might have to get steel on the frount and take off the mech lift or hydro. it can bee done.
olman
08-18-2004 19:59:32
 Re: 3500lb 77 oliver in reply to one wheel wander, 08-18-2004 19:17:07
Thanks one wheel. I have removed the pto and hydraulics. Hope to come close.
ChadS
08-19-2004 11:42:56
 Re: 3500lb 77 oliver in reply to olman, 08-18-2004 19:59:32
If they can get an 88 in the 3500lb class, a 77 should be simple to get lite. We have a 77 in our club at 3480 with a driver, and still has alot to remove on it. ChadS
