Old Engine Show Tractor Pull
Marion Vintage
08-17-2004 16:35:24
Sept 3,4,5 2004 Marion Mi, Blevins Street Track
Sept. 3 6pm.--Farm stock: Transfer sled 3000-4000-5000-6000-7000# 20" drawbar (no johnson bar), no cut tires, 3.5mph speed limit.
Sept 4 10am--Antique Pull Stone Boat, Same wieght classes, 18" drawbar (no johnson bar), no cut tires or radial tires, 1952 or older tractor, 1st or 2nd gear pulling speed.
Sept 5 10am--Garden tractor transfer sled: 13" drawbar, 700-900-1200# classes, Stock tractors only with no attachments, Rims no wider than 12", 1200# Modified Garden Tractor class: 13" drawbar, tires no bigger than 12x12x26, 1 snowmobile engine only, wrist tether and hitch tether is needed, driver must wear helmet and be at least 18 years old.
Jeff Oliver
08-17-2004 18:34:45
 Re: Old Engine Show Tractor Pull in reply to Marion Vintage Power, 08-17-2004 16:35:24
Gonna ask a dumb question here but what is a johnson bar? Does it somehow float so that when the front end comes up he hitch height doesn't change or something? Have never heard of one or at least something by that name.
No Cut Tires?
08-19-2004 15:18:10
 Re: Old Engine Show Tractor Pull in reply to Jeff Oliver, 08-17-2004 18:34:45
When are you guys gonna get up to date and allow top cut tires? It only makes it more of a fair playing field. With a no cut tire rule the guy that has the best luck finding the best road wore tires is going to win. Also, averyone is going to a 1956 and older Antique class. Have you ever considered that?
IH
08-19-2004 19:56:45
 Re: Old Engine Show Tractor Pull in reply to No Cut Tires?, 08-19-2004 15:18:10
If you don,t want to pull these tires pull somewere else.
