engines that BREATHE
Mopower
08-17-2004 13:36:37
A tech question for you fine tuner guys out there: Regarding air velocity and breathing... I was told M-M heads have ports that are too big. Air cannot get the velocity it needs. I also know when switching to big port heads h.p. and torque goes up quite a bit. An old friend said he found a way to compensate smaller ports with a correct cam to match his machine. What is to all this port size, vaccuum, RPM, and cam? I have my own ideas on motors, but I"d like some time tested input. B.S. is ok too!
G-MAN
08-17-2004 13:44:42
 Re: engines that BREATHE in reply to Mopower, 08-17-2004 13:36:37
Generally speaking, smaller ports, smaller valves, lower valve lifts, shorter durations and small valve overlaps induce high velocity and are geared more toward low-end torque than big ports and valves. Proof of this is found in old tractor engines, straight-truck engines and so forth. Due to the low speeds these types of engines run, they can fill the cylinders effectively at low rpms with these features. High-rpm "horsepower" engines need bigger ports and valves, more cam lift and duration and the like to fill the cylinders efficiently at the higher speeds when the valves are open for a shorter period of time. Port shape is also a huge factor in flow. Just look at a new Chevy LS1 engine and it's goofy-looking ports compared to a plain old 350. They look nothing like the old ports but outperform them by a huge factor.
